So I got the GT aligned.. and Does this look right?
Picture has been stepped on for quite some time (which explains the bad image quality), but the rear axle seems to be extremely "off" as well as the front axle. The before alignment sheet (which i don't have) was even worse. What could the culprit be? My car is lowered with the H&r Sport springs. The technician said it wasn't anything to worry about. But I know better than to trust people's words around here. If anything your all's second opinions have always been golden. Thanks.
Also due to either a bad install or just **** springs. The passenger is sitting higher. I have tried countless times to level the car. No luck. I'm about to buy polyurethane isolators and a UPR LCA maybe an UCA in hopes the car will sit level, lol.
these cars tend to sit uneven....its a mustang thing
get coil over sleeves and then you can adjust it to fix it
as for the alignment, it could be better, but as long as you are in the green areas you are fine
Same here Ive taken the springs out to switchs them from side to side with no luck. Let me know how that go's for you, I was thinking about getting some adjustable LCA to help lift the back up some.
uhhh...no. none of my mustangs has ever sat uneven. same with my buddies stangs.
OP: i haven't had that problem before or i would suggest something.
I've never had an uneven drop, with the H&R's on my six or the coilovers I have on the GT, I set the height before I installed it on the GT.
Uneven drop would most likely be caused by a blown/extremely worn iso. I don't remember what the stock GT's alignment specs are anymore so I won't comment on that just yet.
AndySpeed
08-12-2007 05:12 AM
