Too Lean??
All of my mods should be in my signature, i am thinking about getting a throttle body and plenum, would that make my care run too lean? I dont have any fuel mods and have almost every air mod there is, also I have a tuner but not sure how to do a custom tune to make it run more rich. Any help is greatly appreciated.
You should be fine. You will probably want to get a tune done just to add some fuel in certain areas but you will be fine.
so should i get a 75mm or 70mm for an NA stang?
dude i have the same issue i have a 03 GT i have stage 2 clutch, short thro, under drive pulleys, cold air intake, 75mm trick flow throttle body, 75mm trick flow upper plenum and a diablo pradator tuner and flowmaster exhaust im wondering if my injectors are holding me back to i think we are both ok im gunna just bump up my fuel a lil bit just to be safe untill i go get a air fuel meter
Originally Posted by lilcrate
(Post 6258553)
Originally Posted by 03GT5spd
(Post 6258778)
