What is the torque spec for this part?
Im not sure how this part is called, but what is the torque spec for it?
http://img14.imageshack.us/img14/2782/pict0075u.th.jpg |
Sway Bar End Link.. Im pretty sure..not sure of the torque spec though.. I always snug it til the rubber/urethane starts to press out a little and stop.
Originally Posted by jeff37110
(Post 6262279)
I was always snug it til the rubber/urethane starts to press out a little and stop.
But i still want someone to tell me the torque specs on this. |
Like said above tighten until the rubber starts to smash. No torque spec for it.
It's the front stabilizer bar* link, 14 lb-ft...
------------------------ * -often incorrectly referred to as a sway or anti-sway bar, it is more properly an anti-roll, or stabilizer bar as most automotive engineers refer to it. Sway is motion along a vertical axis--flag poles, trees, and tall buildings sway--automobiles roll, which is motion about a longitudinal axis... |
Torque spec for almost anything on a car= tight. Just use common sense. Don't tighten it till it snaps, and don't not tighten it that it's loose.
ok thanks for the info guys
no prob.
Originally Posted by cliffyk
(Post 6262383)
------------------------ * -often incorrectly referred to as a sway or anti-sway bar, it is more properly an anti-roll, or stabilizer bar as most automotive engineers refer to it. Sway is motion along a vertical axis--flag poles, trees, and tall buildings sway--automobiles roll, which is motion about a longitudinal axis... WOW i just put some springs on and did until air compressor said it was done :))))))))))))))) |
you're probably crushing those bushings.... |
