Tail light Problem
Old 06-20-2009, 12:40 PM
apeterman
apeterman's Avatar
Originally Posted by black35th
Put your new bulb in the same socket of the other tailight and see if it works.
They make a 3157 in a single filament and dual filament, my guess is that you got the single. If the bulb does work in the other tailight then you'll know that you have a bad socket, if it doesn't work then you bought a single filament bulb.
I tried swapping the bulbs and still nothing. So I'm thinking the socket.
apeterman is offline
Old 06-20-2009, 12:42 PM
apeterman
apeterman's Avatar
Originally Posted by BlueBloodedPony
He already tried replacing it, he says the new one still isn't lighting up. I have had this issue before with mine. With the lamp out and lights on try jiggling the bulb and socket and see if you can't get it to light up, then if you do, track down which wire it is and see if you can fix it. My issue was the socket was going bad, so I replaced it.
I have called a few car parts places and nobody has a new socket. Did you get yours from a junkyard?
Old 06-21-2009, 09:56 AM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
Yes, I cut a pigtail from a wrecked one. Get like 5-6" of wire with the socket and then splice it in.
ChalknCover is offline
Old 06-22-2009, 11:29 PM
apeterman
apeterman's Avatar
ok cool thanks.
JonnyBlazeGT
11-03-2015 01:10 AM
kdryan
08-21-2015 04:01 PM
jjwinel78
08-17-2015 03:34 PM
chain
08-17-2015 08:52 AM
philster0306
08-10-2015 11:33 AM
Quick Reply: Tail light Problem
