Losing gear oil behind brake
Well the first stock part on my car finally went bad. I have an 04 GT with 60k miles, for clarification's sake.
I was under my car pulling the exhaust up a little higher and looked over to the passenger side rear brake and saw the back of the caliper covered in oil. I figured the smell of gear oil was from the breather (my exhaust was touching the breather and stopping it from being open, as well as hitting it)... There was a small spill around it.
So now I have the problem of fixing this before it becomes a bigger problem. I am supercharging my car in a couple of weeks so the timing of this is frustrating. I am thinking the axleshaft seal/bearing failed, but it doesnt cause any weird noise and it can't be leaking terribly fast.
If this is the issue though, fixing it won't be bad, I just need to know before I tear my oily brake off and clean it up. Suggestions anyone?
Yeah, definately the axle tube seal. It looks like an involved job, but if your mechanically inclined it really is pretty simple. I just put new axles, differential, seals and bearings in mine and it wasn't too bad of a job.
Where'd you get the seal? And any guide on getting the existing one out? I'm assuming I'm going to need a slide hammer, and am capable of doing it, just haven't taken on something like this before.
I've got a haynes manual around somewhere but I really don't trust it.
musnicki
09-23-2015 07:11 AM
zanemoseley
09-06-2015 12:58 PM
09-03-2015 07:14 PM
