clicking sound from passenger side fender
i Just put back my ecm and when i went to start the car i got a funny clicking sound coming from the passenger side fender area i cant pinpoint where it is coming from. Another this is the car now refuses to turn over any ideas?
The clicking sound is probably coming from your fuel pump relay.
That clicking sound is probably coming from your fuel pump relay which is installed in your Constant Control Relay Module located between your passenger side fender and fender well, as shown below. I believe the Constant Control Relay Module is equipped with 3 relays. One for your fuel pump, one for your A.C. Compressor, and the other for your cooling fans. You said that after you installed your ECM, your engine now does not turn over. What was the reason for your ECM being removed in the first place? When you removed your ECM, did you disconnect the negative battery cable from the battery first, or did you remove the ECM with the battery still hooked up? If your answer is yes, that means that you re-installed your ECM with your battery still hooked up! Let us know. Good luck, Tommy.
I am having a similar troubleshooting issue, i need to check and clean my ecm, i need some more details on this and how to locate and clean it. Thx.
