Where does this go?
Wire Connector with two black wires?
Are you sure that none of the wires has a color stripe on it? I found some two wire connectors that you may want to check on. The colors are not a good match but I think worth checking on anyway. You may want to check to see if these items are working:
Windshield washer pump motor:
1-BK/white stripe
2-BK
Positive crankcase ventilation heater:
1-RD/BK stripe
2-BK
Parking brake switch:
1-LB/BK stripe
2-BK
Lumbar adjust switch left front seat:
1-BK
2-BK/White stripe
Door ajar switch, left front:
1-BK
2-YE/BK stripe
Still looking. When I find something, I'll post it. Recheck the two wires, look for stripes on them. Good luck, Tommy.
1-BK/white stripe
2-BK
1-RD/BK stripe
2-BK
1-LB/BK stripe
2-BK
1-BK
2-BK/White stripe
1-BK
2-YE/BK stripe
Here's what I did. I checked my son's 2003 GT Mustang. The picture below is of his engine compartment. I checked the driver side of the engine compartment and the only wire connector with black wires are used for grounding purposes. This wire connector is located just aft of the battery, clipped to the fender well. It is not easily seen. It is located below all of the wires that are positioned at the top of the fender well. You really have to look good to see it. Not sure if yours was hooked up the same way or if this is the same wire as yours. I could not follow the wires in the direction of the fire wall. However, I could follow the wires as they ran forward of the engine compartment from the wire connector. Identified by arrows, one of the black wires runs directly to the negative battery cable, the other runs to the round ground clip and secured to the car's body. What you can do is check both teminals of the wire connector for voltage with the key off, then with the key on. If you don't pick up any voltage, check both terminals for ground. If you pick up ground on both terminals, you should find the matching wire connector and ground the wires as shown in this picture. These wires must support one or two circuits some where. Hope this helps. Good luck, Tommy.
I tried to copy and paste from another thread I found but couldn't get the pic to show up. Here is the thread it has a wiring harness in it. https://mustangforums.com/forum/4-6-...6k-beware.html
Engine wiring description
Thanks to highpsi04, I was able to get the engine wiring description posted here. So, I may be correct. It could be the ground wires at 19 or 21. Good luck, Tommy.
Item
Part Number
Description
To crankshaft position sensor
To A/C compressor
To radio ignition interference capacitor (2)
To fuel injectors (8)
To ignition coils (8)
To engine coolant temperature sensor
To throttle position sensor
To idle air control valve
To EGR vacuum regulator
To differential pressure feedback EGR
To fuel pressure regulator
12
Fuel injection ground
13
To generator
14
To camshaft position sensor
15
To body
16
To heated oxygen sensor (2)
17
Engine bulkhead connector
18
To low coolant sensor
19
To body
20
To power distribution box
21
To body
Item
Part Number
Description
To A/C compressor
12
13
To generator
14
15
To body
16
17
18
19
To body
20
21
To body
Engine wiring discreption.
