The H pipe install
Old 07-01-2005, 12:01 AM
ReVz
ReVz's Avatar
Default The H pipe install
Was wondering... how hard is it to put on an H-Pipe yourself?
ReVz is offline
Old 07-01-2005, 12:02 AM
David_K
David_K's Avatar
Default RE: The H pipe install
depends on how many peices the H-pipe is in. the more the easier
David_K is offline
Old 07-01-2005, 12:08 AM
josh_0351
josh_0351's Avatar
I'd have a torch handy in case your header bolts are seized on like mine were and you have to heat the bitches in order to break em loose![:@] Other than that, it's cake!
josh_0351 is offline
Old 07-01-2005, 02:39 AM
2k1gt
2k1gt's Avatar
Mine was two pieces and it was really easy to put on.
2k1gt is offline
Old 07-01-2005, 02:42 AM
primetime5.0
primetime5.0's Avatar
passenger side lower is teh hardest evar!
primetime5.0 is offline
Old 07-01-2005, 03:40 AM
jkm1987
jkm1987's Avatar
i did mine it was too bad just get some pb blast and some decent extensions and do it when the car is cold or you will burn your arm a million times on tranny i learned taht the hard way
jkm1987 is offline
Old 07-01-2005, 11:31 AM
mk636
mk636's Avatar
I know you said H, but I just installed a one peice catted X on mine by myself. Took about an hour. And yes the passenger side is a bit of a pain.
mk636 is offline
2007CalSpec
12-13-2020 11:42 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Webster454
09-07-2015 04:59 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: The H pipe install
