Best UCA's/LCA's besides Maximum Motorsports?
Old 07-02-2009, 01:53 AM
StriderTacticaL
StriderTacticaL's Avatar
Default Best UCA's/LCA's besides Maximum Motorsports?
So I wanna get some control arms soon with the lowers being more important. I know that the MM ones are the best and I can understand the $250ish pricetag on the fixed ones but not the $460 for the adjusables. I think I am gonna want adjustables so I was wondering what the next best brand out there is? Unless the MM ones are truely worth the $460?
Thanks,
Brandon
StriderTacticaL is offline
Old 07-02-2009, 06:00 AM
texas_stang02
texas_stang02's Avatar
you know i hear both ends of the spectrum about UPR.. some people say they're complete junk, and then some people say they've been running their parts for years with no problems. only reason i mention UPR is the cheaper price, although if they're junk then you're not really saving in the long run.
texas_stang02 is offline
Old 07-02-2009, 07:24 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I've been hearing the same thing, Texas
I have decided to just recommend a very heavy duty LCA that is more expensive, but will hold up under heavy launches at 1/4. It will also help alleviate some of the bind cause by not only the stock LCA's, but a HUGE amount of aftermarket ones typically sold for the Stang.
Griggs MCA 4500 S-99
These have a poly/spherical end and are also adjustable (the picture on page is incorrect, so pay it no nevermind as it is NOT the one in description). These will add some NVH to your ride, but so will all aftermarket arms.
As for UCA's, I still like the UPR Pro-Series as I have not found a heavier one that does not require additional components to run them.
Jazzer
Jazzer The Cat is offline
Old 07-02-2009, 08:04 AM
stang04chris
stang04chris's Avatar
Look in to baseline suspension, that's what ill be getting
stang04chris is offline
Old 07-02-2009, 09:16 AM
DreamerGT
DreamerGT's Avatar
Ive had my eye on these for a long time. They look pretty good, if anyone has anymore info on them http://www.hotpart.com/shop/index.ph...ct_detail&p=51
DreamerGT is offline
Old 07-02-2009, 01:24 PM
SilverGT03
SilverGT03's Avatar
I'd say it all depends on the car. A set of UPRs should be fine for a bolt on gt, however once you start throwing stickier tires and power adders into the equation I would go with a more heavy duty one. Amount of time at the track is also a factor to consider. If you're there every other day making passes you may also want to go with a stronger control arm. Just my 2 cents...
SilverGT03 is offline
Old 07-02-2009, 02:30 PM
devongarver
devongarver's Avatar
definitely check out baseline, atleast for the uppers. Infact, email kevin at baseline, he can help you out alot. http://www.baselinesuspensions.com/
tech@baselinesuspensions.com
devongarver is offline
Old 07-02-2009, 04:25 PM
ddmsgtr1
ddmsgtr1's Avatar
I've only heard bad things about the poly UPR setups, not the solids. But after talking to a shop, the word is if you're doing a lot of launching, sphericals are the way to go. For a bolt-on GT, polys might hold fine, but once you start running more power or start throwing nitrous or FI at it, your gonna start eating polys up. Isn't that the problem that everyone here dipping into the 12's had with the summits??
ddmsgtr1 is offline
mtgldr
02-03-2024 09:00 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
robcy
Suspension
10-27-2015 11:14 PM
UrS4
10-03-2015 06:23 AM
09-16-2015 07:53 PM
Quick Reply: Best UCA's/LCA's besides Maximum Motorsports?
