Installing my pro-kit today....
RE: Installing my pro-kit today....
ORIGINAL: whitehorsegt
when i put my c-springs on my old 03 gt...i put the buttom part in first then the top part...
ORIGINAL: kubball2005
Alright, did you have to really compress the top part?
...did u unbolt the endlink and the a-arm is all the way to the floor?....then did u compress the strut out of the wheel well?..and just use a crowbar to take the spring out...then oh wait wait....ACTUALLY u have to put the top part in and just alighn the spring with the pig tail end facing the drivers side then give it alittle kick or use the crow bar again...should take like 10 min..
ORIGINAL: code3GT
Do you have a spring compressor?
The backs are really easy... the fronts suck bad...the whole job took me like 4 hours I had the drop the whole brake assembly and everything cause I couldn't remove the big bolt that attatches to the arm. It sucked but well worth it.
