Different size water pump
So I went and picked up a remanufactered water pump today and it is a good bit shorter than my old one. My tuner had said that it looked like I had a lightning water pump on my car before. Looking online, the lightning pump does look to be about the same size. Am I correct in assuming the the new pump won't work with the pulley off the old one since its shorter and should I get a different pulley or another lightning water pump..
the GT's had 2 diff pumps......96-01 1/2 was a shorter pump and 01 1/2-04 was a longer pump (it may be the other way around).....jvog i have my original pump with hardly any miles on it , you can have it if you want it ....just let me know
Well the pump I got was for an 02 GT and its a lot shorter then my original one. Camd can ya measure it for me?
i ran into that problem myself on my conversion, i was going to use the gt pulley on the mark 8 engine but the mark 8 pump was longer so i just used the lincoln pully instead, i do still have the pully for the short pump if you can use it.
Yea I could use it. Whats the difference, just that one pulley has more backspacing then the other take make it stick out further.
well the 2 pulley's i had look quite a bit different but effectively the only difference is the backspacing. the only other difference is the gt pulley has a flange to keep the belt from coming off the front of the engine, and the mark 8 doesnt.
11-10-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
