pi head swap help
pi head swap help
here goes i did the pi head swap on my 1997 mustang gt the car runs but like crap it wont idle or stay runing i get a p0340 code iv all so had a pats problem i fixed that it was a ground wire trying to fix the pats i changed the crack sensor cam sensor lat sensor im going to get o2 sensor tomorrow i read if antfreez or water get down the exhaust value it can mess with the o2s but iv also read that the Alternator my cause rough idle and stall to ? the last fuse in the box closest to the finder the little one 25 amp blows every time ? any one know what that fuse goes to ? or were the short mite be ? / im just going to start thorgh parts at it till i fix it iv been trying to fix it for months now if i had a bent value wood that make it run like that ? /it does not seem to have a vacum leak / bad injecter ? bad oring somthing/im geting sick of working on it and the old lady yelling
Here goes. I did the pi head swap on my 1997 Mustang GT, the car runs but like crap, it wont idle or stay running. I get a p0340 code, I've also had a pats problem, but I fixed that, it was a ground wire. While trying to fix the pats, I changed the crankshaft sensor, camshaft sensor and IAT sensor. I'm going to get an o2 sensor tomorrow.
I read that if antifreeze or water gets down the exhaust value it can mess with the o2 sensor, but I've also read that the alternator may cause it to idle rough and stall. The last fuse in the box, the one closest to the finder, its the little 25 amp blows every time. Any one know what that fuse goes to or were the short might be? I'm about to start throwing parts at it till I fix it. I've been trying to fix it for months now. If I had a bent value would that make it run like that? It does not seem to have a vacuum leak or a bad injector. Maybe it's a bad o ring or something. I'm geting sick of working on it and the old lady yelling at me
If the car ran fine before the swap, I would put money that it is something connected to the swap.
Vacuum leak, ground not hooked up, timing, etc. I would look at timing and a vacuum leak before replacing any parts.
Matt's 95 Stang
10-05-2015 07:16 AM
