Stiff clutch
It was sugested that I post in this forum for help. Please see thread.
https://mustangforums.com/forum/4-6l...ff-clutch.html Thanks! |
Well the clutch in your car is a cable clutch and if you are use to a hydraulic clutch... that will be a huge difference right off the bat. Plus you could also have an aftermarket clutch, which would also increase the pedal weight.
I think it's just an adjustment period for you. If you've never driven one before, the clutch is WAY different than your usual shifting experience. I learned stick on an old subaru. The first few months, there was quite a bit of rocking and jolting with the stang (this is after 10 yrs driving stick).
It's just a different beast when it comes to shifting. |
Originally Posted by rainydayracing
(Post 6354231)
Originally Posted by scooter3
(Post 6354295)
Thanks. I kind of figured, but thought I would ask. I guess I was used to the clutch in my Speed3 which was smooth and easy.
It's a cable clutch, plain and simple. I learned on a Saturn SL2, after driving my mustang, I nearly kicked the clutch pedal through the floor pan. It has about a week long learning curve to get your leg adjusted to it.
