stock c/c plate adjustment with bolts - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Reload this Page >
Old 07-19-2009, 06:20 PM
sstang
Default stock c/c plate adjustment with bolts
I'm in need of a major alignment as my car is pretty low with 4 cylinder fox body springs cut half a coil. I still have the stock c/c plates but have read a little bit that people drilled the rivets out and put bolts in their place to give more adjustment? Can anyone shed a little more light on this for me as to how this is done, where to get these c/c bolts, etc. Thanks.
sstang is offline
Old 07-23-2009, 01:53 PM
sstang
bump...
sstang is offline
Old 07-23-2009, 02:46 PM
PaintballFreak
PaintballFreak's Avatar
I would say, do it right and get the CC plates. If you start drilling holes into your strut towers then need to put in cc plates later, you might have screwed yourself.
PaintballFreak is offline
Old 07-23-2009, 03:23 PM
Ultimeas
Im pretty sure on a regular alignment on mustangs (and lots of other fords that have this setup), you HAVE to drill the rivets out, then loosen the bolts and (usually use a hammer or something), shift the strut over a bit.
Ultimeas is offline
Pyrate Dave
09-10-2015 08:30 PM
RWHEELS
09-05-2015 04:42 PM
raleigh05GTO
09-04-2015 08:09 AM
Luke9222
09-04-2015 07:46 AM
Quick Reply: stock c/c plate adjustment with bolts
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
