Nobody has installed this before?
http://www.steeda.com/products/speed...tion_gears.php
Trying to figure out if i should buy this with my 4.10's, they will be here tomorrow, nobody's said if this goes inside the differential or trans or what. any help? i'd appreciate it.
Well you're going to need the white one, its not in the rear... Its on the end of the speedo that bolts into the driver side of the trans. Its an easy swap. however the 23tooth probably wont last long, since it isnt technically a ford made part.. It wont mesh perfectly and has been known to fail. I'd recommend a speedcal if it were my car
Best bet is leave the speedo gear you have in there and get a Speedcal from Dallas Mustang
The speedcal gets hard wired in series with the wires from the speedo cable sensor. Its adjustable to any gear ratio / trans ratio I believe..
And the little gear itself is plastic, and will most likely strip and you'll need to replace it.
Who told you it wouldnt work with 96-98?? Last time I checked it will work, and works pretty well...
