2000 GT, 77k miles,5 speed, feels sluggish lately, bucking at low speed.
Hi I have a 00 GT w/ 77k miles and Ive noticed lately it feels sluggish as in it doesnt accelerate nearly as well (or fast) as it normally would. Also at low rpm, say im in 2nd gear and not giving it a lot of gas you can feel a slight bucking sensation back and forth. im assuming this is related to the reduced power on acceleration but im not sure what I should look at.
The car is all stock except for a centerforce dual friction clutch.
Maintenance wise in the 2 years Ive owned it ive keep up on the oil / filter changes every 3k miles, 4-5 months ago I had the transmission and rear-end fluids serviced, had the air filter replaced,and put new brake pads all around.
Maybe im due for new spark plugs?
Any ideas appreciated!
OP, just so you know, that is a joke. If it's cracked, it will shock the ever loving **** out of you. There are test lights that you can use to see if it's sparking, I have one that works good. Check the drivers side plug, closest to the thermostat housing and make sure that it's dry. I had that issue and it was filled with antifreeze.
