Fed up with my gauges
Old 08-09-2009, 07:15 PM
Evenexchange
Evenexchange's Avatar
Default Fed up with my gauges
My car ALWAYS reads extremely hot. When I shut my car off, it settles at almost halfway and will not go down to 0. I have taken off the plastic cover and tried moving it to 0 but it just goes back. Had the engine temp check, running normal IDS at 193 degrees. What DO I DO???
Evenexchange is offline
Old 08-09-2009, 07:16 PM
Evenexchange
Also, the guy before me put in steeda gauges, that's probly why it's broken.
Old 08-10-2009, 06:17 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You need to pull the needle off and reposition it on the gauge shaft.
cliffyk is offline
Old 08-11-2009, 12:54 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
If you can take the cluster front plate off, plug the cluster in and get it to normal opperating temperature. Then do what cliffyk said and pull the needle off the shaft and put it on while it's pointed in the middle
PROMETHEUS PRIME is offline
Old 08-11-2009, 04:19 PM
Evenexchange
I tried that once, but didn't think that it would just come off? I was was afraid of breaking it... is there any particular method? Do you pull on the fat part of the needle?
Old 08-15-2009, 10:23 AM
Evenexchange
Anyone have any ideas?
Old 08-15-2009, 05:00 PM
mustangmikey88
mustangmikey88's Avatar
i put stack racing guages in i just let the car sit over night so it was for sure cold set the needle at the bottom and it works great
mustangmikey88 is offline
Old 08-15-2009, 05:30 PM
PROMETHEUS PRIME
Pull straight up from the round base part. If you pull from the needle part it will break
Old 08-17-2009, 11:59 AM
devongarver
devongarver's Avatar
yes go to sears hardware, ask for/locate a Tach Puller. Its got a screwdrive type handle, and a forked wedge foot on the end, its made for doing just this sort of job. its like 7 bux.
devongarver is offline
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Fed up with my gauges
