Oil leaking under the procharger?
Old 08-20-2009, 09:48 AM
1995procharged
1995procharged's Avatar
Default Oil leaking under the procharger?
i took my intake off to clean the air filter and thats when i noticed oil all over the bottom half of the procharger. Any one have any suggestions on what i should do
1995procharged is offline
Old 08-20-2009, 10:01 AM
03BottleFedGT
03BottleFedGT's Avatar
first thing clean it off an find out where it is coming from
03BottleFedGT is offline
Old 08-20-2009, 05:46 PM
99 GT vert
99 GT vert's Avatar
My guess is that the pully shaft seals went out when my cousin bought his D1 his seals were bad. There is a place were tou can buy better aftermarket ones
99 GT vert is offline
Old 08-21-2009, 05:48 AM
uberstang1
Chupacabra
uberstang1's Avatar
Well first like said before you have to find out where its leaking, if its leaking from behind the pulley you're best bet would be to send it out to procharger for a rebuild, roughly 700$. If you have an older style procharger like a p600b it could judt be you need to titen the inlet oil line and teh return line underneath the head unit.
uberstang1 is offline
Old 08-21-2009, 08:50 AM
Eagle2000GT
Eagle2000GT's Avatar
First question, how much oil? A little of the ProCharger oil goes a long way. I was accidentially over filling my brand new P1-SC and ended up with oil on the bottom of the head unit and on lines under the supercharger. It seemed to be everywhere even though there was no obviously drop in oil on the dipstick. Oil was seeping out the fill screw.
As the instructions said I was using a full bottle of oil when I changed oil in the head unit. But if I looked at the dipstick, I was actually overfilling the unit. I have since cut back on the amount of oil I put in and it stopped blowing so much oil out the vent on the fill screw.
Eagle2000GT is offline
Old 08-21-2009, 12:25 PM
Chris98Gt
Chris98Gt's Avatar
The drain plug may not be tightend enough, or it could be the seal on the fill plug, mine was leaking and when I changed the oil I replaced the seal and no more leaks. It could also be from the last time the oil was changed and they tried to do it with the blower still on the car, I tried it once that way and made a mess everywhere, they may not have cleaned it up.
Chris98Gt is offline
Old 08-30-2009, 04:11 AM
1995procharged
Thanks for the help i got this car about 3 weeks ago and the guy a got it from did a half *** job on it but im taking it to a shop next week to get it worked and have them fix everything because i know nothing about prochargers and i dont want to take a chance on screwing something up.
Old 08-30-2009, 03:02 PM
pcs
pcs's Avatar
i would check the dipstick on it just to make sure you arent running it w/o any oil then you end up destroying the gears inside.
pcs is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Oil leaking under the procharger?
