How much power???
How much power???
Hey guys, check my sig. How much RWHP do you think my engine can take, right now I'm at 417. My tuning guy won't give me a straight answer. I do not want to intercool it right now, so just what's on it now. Right now I am at 10-11 psi, A/F 11.5 across the board. Not sure of the timing, but my guy says he has a conservative tune in her so I don't break anything. As a side note, I grenaded my stock motor at 54K miles, 30K of that she was supercharged. Had the new motor put in 6000 miles ago. Still has stock 2 valve heads though. On second thought, factor in both intercooled and not, too. Thanks.
I would say 700+ with a built short block, but the most I've seen on a boosted 4.6 2v with no intercooler was low 500's
I made 516 with stock heads and valve train. Heads do not determine the dependability unless you're spinning a lot of rpm.
With stock heads (i have comp beehive springs/comp retainers) with CMS 2.5 blower cams how much is too much rpms with stock heads - I have a forge MMR short block?
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
