I did an engine swap and am down to the last couple of steps. I cannot get my heater core hoses to attach at the firewall. I tried forcing them on, but they just won't go. What's the deal...
I've attached an image below and highlighted the area in red...
There should be 2 white clips that fit into the hose end. Part of it fits into the square openings. You might have to go buy 2 if they are nowhere to be found along with the o-rings that go inside
Off subject a little bit, but that looks like a cobra motor not a bullitt motor..Very clean looking install though btw...
Yeah, that is a Cobra motor in the pic. It was the best one that I could find online to give you guys an idea of what I was talking about. I'll post pics when I wrap everything up.
Prometheus, That's exactly what I was missing. Thanks!
Throw the stock ones away and just use 5/8 heater hose and clamp them on. Not that hard.
I would think that because that are flanged and tapered that they would require the clip as well as the correct hosing as it is shaped to fit the nipple exactly.
