The Daily Grind
The Daily Grind
Alot of time when I shift into reverse, it doesn't feel like the stick settles into the proper position. I'll let off the clutch and I'll it won't catch and I get a grinding sound. The sound is similar to when I just miss shifting correctly but a little less intense. Also, when I'm driving, I more often then not, grind the gears when I'm shifting into 3rd and I can tell you that it isn't driver error. Any idea what might be going on?
RE: The Daily Grind
it could be something as simple as needing to replace your gear oil, i'd give it a shot, it's a good thing to do anyway
i'd suggest redline, it's good stuff
and for the record, The02GT has the best avatar ever.
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
JDWalton
09-24-2015 08:47 PM
09-10-2015 08:39 PM
