After my drop!!
Old 07-09-2005, 04:57 PM
kubball2005
kubball2005's Avatar
Default RE: After my drop!!
ORIGINAL: SilverGTV8
Well it sounds like you already checked to make sure the spring is seated right.
Removing the upper isolator will drop it that extra 1/4 inch you are looking for. You may pick up a little noise doing it but you shouldn't hurt the car doing it. I know of several people on other boards that have removed them with no ill effects.
Thanks a lot man, I'll go put it all back on and see if it helps it out.
kubball2005 is offline
Old 07-09-2005, 05:55 PM
kubball2005
I reinstalled the spring without the isolator and it's still not as low as the driver's side. In fact, the entire passenger side is higher than the driver's side so I don't know wtf is going on. Maybe I'm just being too picky about it but I know i'm not wrong in thinking it would all look level... has anyone who put the pro-kit on experienced this?
Old 07-09-2005, 06:08 PM
mustang_montana
mustang_montana's Avatar
looks real tight! how long did it take you? i wanna drop mine soon also.
mustang_montana is offline
Old 07-09-2005, 06:37 PM
kubball2005
ORIGINAL: mustang_montana
In all it took me around 4 hours because the mustangworld instructions didn't have in their instructions that you needed to unscrew the tire rod or whatever. So once I got that off the whole assembly dropped so much more so I could get the shock out of the wheel well. Then I couldn't figure out how to get the new one in and I finally got it in by my friend prying it up and me kicking it into place. The front two take the longest and it would have taken me like 30-45 min to do the rear ones but I replaced the shocks too. The rears are really easy though.
Old 07-09-2005, 09:50 PM
mustang_montana
i think ill be going with tokicos adjustables spring and struts package after the engine is in. gonna try doing it myself, just have basic tools though no air or anything.
Old 07-10-2005, 03:31 AM
BraMas
BraMas's Avatar
Your car does look great! Did you try taking both front springs out and making sure they are the same height. If everything is right you shouldnt have one side lower than the other.
BraMas is offline
Old 07-10-2005, 03:46 AM
kubball2005
ORIGINAL: bramas02
I didn't check if they were the same height but they were the front springs.
Old 07-10-2005, 04:33 AM
sickspeedgt
sickspeedgt's Avatar
Looks sweet as hell, and you saved some cash by doing it yourself. Good job
sickspeedgt is offline
Old 07-10-2005, 12:28 PM
StangTangGT
StangTangGT's Avatar
cut off half a coil or so if it doesnt settle in a week
StangTangGT is offline
Old 07-10-2005, 12:30 PM
SilverGTV8
SilverGTV8's Avatar
Now that's a bad idea[]
SilverGTV8 is offline
Quick Reply: After my drop!!
