After my drop!!
Old 07-09-2005, 02:59 PM
kubball2005
kubball2005's Avatar
Default After my drop!!
Well the before pic is still in my sig, but here's how the drop looks. I think I'm going to have to take another look at the passenger front spring because it hasn't dropped as much as the driver's side has. I don't know if you guys can really tell from these pics but it needs to go down another 1/4-1/2 inch. I think the driver's side looks sweet though.
kubball2005 is offline
Old 07-09-2005, 03:14 PM
03GTType
03GTType's Avatar
Default RE: After my drop!!
Looks great! No more 4x4..
03GTType is offline
Old 07-09-2005, 03:32 PM
Acer2428
Site Mod
Acer2428's Avatar
Take the upper isolators out.
Looks good.
Acer2428 is offline
Old 07-09-2005, 03:38 PM
NoisyPony
NoisyPony's Avatar
Which spring set did you use? and how does it ride?
NoisyPony is offline
Old 07-09-2005, 03:48 PM
kubball2005
ORIGINAL: Acer2428
Looks good.
Well I have the car jacked up and the wheel off and the spring on front passenger side looks fine. It's in there good, the pig tail on the bottom is facing the same way the stocker was and the isolator looks good. Should I really try taking the top isolator off or does that hurt the car or the ride?
I have the pro-kit.
Old 07-09-2005, 03:57 PM
devinsteen
devinsteen's Avatar
Dude, that looks much better! I don't know about the isolators, but it looks damn fine.
devinsteen is offline
Old 07-09-2005, 04:00 PM
kubball2005
ORIGINAL: devinsteen
Thanks, the ride is the same as before and I can tell that the handling tightened up a bit which feels really nice. It's just this one side that's annoying me. I want it all to be level!!! [:@]
Old 07-09-2005, 04:30 PM
kubball2005
Ok well the spring's out again and it's all apart in my garage so I could really use some opinions on how to fix this problem. I'm thinking about the isolator idea like acer said but I don't know if I wanna do that or not.
Old 07-09-2005, 04:37 PM
blueangelfightr
blueangelfightr's Avatar
You have a really fat person sit on it until it goes to the height u want. [8D] BTW The car looks good.
blueangelfightr is offline
Old 07-09-2005, 04:56 PM
SilverGTV8
SilverGTV8's Avatar
Well it sounds like you already checked to make sure the spring is seated right.
Removing the upper isolator will drop it that extra 1/4 inch you are looking for. You may pick up a little noise doing it but you shouldn't hurt the car doing it. I know of several people on other boards that have removed them with no ill effects.
SilverGTV8 is offline
Quick Reply: After my drop!!
