EGT where is best place
Old 07-12-2005, 02:37 AM
num1son80
num1son80's Avatar
Default EGT where is best place
On my o2 gt (long tubes installed) where is the best place to install the probe without taking the headers off, so if its on a lift where is the best place to mount it, I doubt the collector since I'm sure the gases would cool off by the time it reached there, anyone get it done..
K
num1son80 is offline
Old 07-12-2005, 06:13 PM
num1son80
num1son80's Avatar
Default RE: EGT where is best place
I think I'm gonna bump myself I know someone is running an egt gauge
K
Old 07-12-2005, 06:18 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
The best place for it is in the mid pipe just after the header connection. Mine is on the driver side.
jdaniel is offline
Old 07-12-2005, 06:23 PM
David_K
David_K's Avatar
why do you need a EGT gauge? heres what i did. i got an aviation EGT gauge that had 4 sending units one fore each slinder cept these sensors were like the size of a small carrage bolt head.
that way there was absolutly no restriction what so ever
David_K is offline
Old 07-12-2005, 07:54 PM
The Great Cornholio
I ♥ Acer
The Great Cornholio's Avatar
ORIGINAL: jdaniel
That's further downstream than recommended. The closer the pyrometer sensor is to the cylinder head the better.
The Great Cornholio is offline
Old 07-12-2005, 10:54 PM
num1son80
num1son80's Avatar
I thought I wanted to keep the gauge close to the heads... that far down by the collector has to have some varience and cool down so I would think it wouldnt give close numbers at all, btw was is the optimal/safe temp for our NA cars
K
Old 07-12-2005, 11:02 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
Well you have to remember... I dont have LT headers, so mine is right by the heads bassically.
jdaniel is offline
Old 07-12-2005, 11:05 PM
num1son80
num1son80's Avatar
so even with long tubes wouldnt u want it as close to the heads as possible???
K
Old 07-12-2005, 11:52 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
ORIGINAL: num1son80
K
Thats what they say... but your temps arent going to cool down much at all between the head and the collector... ESPICALLY if you have ceramic coated or Jet hot coated headers... and please tell me you have the ceramic or jet hot headers. I wouldnt have wasted my money on just regular ones.
jdaniel is offline
Old 07-13-2005, 12:01 AM
num1son80
num1son80's Avatar
jet hot coated $500 out the door, I'm sure I could have found cheaper but summit had them in stock
K
Quick Reply: EGT where is best place
