NEW idle air controller... still shuts down when i'm stopping
i'm in the same boat man, i've cleaned everything, checking everything but the hood pins to see what the deal is. heading home hopefully in time enough to get this started and do the TB and clean the Aircleaner and MAF by the beginning of next week. I have the exact same symptoms expect the bogging, it has a rough idle though. seems like i have a cam in it... or several cams haha,i wish, but i don't. i'm worried its something a bit more serious.
Is is an OEM replacement MAF, or something else?
[QUOTE=SVTeeshirt;6486035]
Bogging is generally an overly rich mix, severely retarded spark, or a loss of charge velocity from a grossly oversize throttle body...
just a muffler, i even swapped my x-pipe back to stock, stock TB i did buy a new MAF cleaned the IAC. I did find some wire that was poorly taped to say the least and was corroaded so i stripped down to good wire put em back together and retaped, it was arc-ing so bad im suprized it didn't catch fire, i found a crack in the hose that runs from the intake tube back across the middle to the intake manifold (4v) and replaced the hose, cleaned the IAC. Replaced the sparkplugs and wires/ Coolant temp sensor(autozone told me it was throwing CTS mod). Then still bogging, better but still bogging, as well as shutting down whenever i would put my foot on the clutch from a high rate of speed, if i downshifted to slow the car would shut off and come back to life once i let off the clutch, if i didn't let off the clutch it would simply shut off.
Im hoping its not a horrible wiring issue, im thinking i should have replaced the IAC but after i did pretty much everything listed above i took it for a diagnostic test and they told me i needed new plugs and wires.... when the plugs and wires in there were 2 weeks new, with the correct gap, oh and the wires seemed to be burned near the plug. what would cause this?
with that said it was enough to make me pull the car off the road and just do a complete rebuild, but i'm still wondering what the hell was causing this... should i have replaced the IAC? i was just so fed up with spending $ on it.
will do, i'm going to have to fine comb this SOB, cause im worried she's on her last leg. its tough... do i save for a rebuild kit, or do i put a petty $50/$100 in a part here and a part there and something here or there to try to keep it kicking just a bit longer.
Dude I had a 96 Cobra. I had some issues with mine to but mine was only 4 years old when I bought it. Yours is almost 15 now its going to have problems. Those cars have been beat up like a hooker on dollar night.
uh..yeah.. its gunna have problems, and now i want to fix them. i have an entire rebuild in the garage, but i am trickling it in slowly but surely cause of money. NOW this morning, the car barely started... new symptom, i hate the key, it chugged around, and then rose rpms REAL slow to idle after a short rough start. interesting...never done that before either.
