Excellent, you wouldn't happen to know the actual part name or number so they know what I'm talkin about do ya? Also, there is a metal bracket of some sort surrounding the fill tube, and it seems like it is not holding anythign in place. Should it be?
It's the fuel filler neck tank gasket or seal. It Sucks @$$ to change. Also check & make sure the fuel tank straps haven't worn through the plastic. I've seen the things rust through, and wear holes in the fuel tank causing leaks. I was chasing that problem with my 92 SHO. Both seam to be a PROBLEM up north from the salty winters.
