help my 0 to 60 time
Old 09-12-2009, 03:49 PM
0949er
0949er's Avatar
Default help my 0 to 60 time
Ok so with all my mods listed below, I cannot break 5.5 secconds for 0-60. I know that my problem is about 99% traction (I spin until I hit third gear).
So what are my options? Should I work on suspention, or should I just buy wider rear tires? (I have the stock 8" or so). Would lowering the car any help?
0949er is offline
Old 09-12-2009, 04:20 PM
Lowtryx
Lowtryx's Avatar
I'm not so sure lowering the car would allow you the traction you are looking for. It's very true that you can have alll the horses in the stable but if you can't plant them, it's all for nothing. Suspension is the way to go.
Lowtryx is offline
Old 09-12-2009, 05:17 PM
hot sauce
hot sauce's Avatar
Suspension and better tires
hot sauce is offline
Old 09-12-2009, 05:23 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Wider tires and suspension mods. I don't think lowering springs help you in a straight line (could be wrong).
Check out the Suspension sticky in the 4.6 section and the choosing the right tire sticky in the wheel and tire section.
WannaBeGearHead is offline
Old 09-12-2009, 06:25 PM
Capt Hair
Capt Hair's Avatar
LCA's and SF connectors my friend.
Capt Hair is offline
Old 09-12-2009, 07:49 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
*** nevermind, i thought you were talking 60's not 0-60, misread
99BlackPonyGT is offline
Old 09-13-2009, 01:24 PM
boduke0220
boduke0220's Avatar
well you have Supersports like me so that doesnt help much lol but SFC's CA's and wider/better tires will help a ton
boduke0220 is offline
Old 09-13-2009, 01:35 PM
02stangdude
02stangdude's Avatar
drag radials, upper and lower controle arms, shocks struts. i think drag radials will help the most tho
02stangdude is offline
Old 09-13-2009, 01:39 PM
35annGT
35annGT's Avatar
look into lower control arms. i have steeda solid lower control arms and noticed a huge difference IMO still have to install rear upper adjustables though..good luck
35annGT is offline
Old 09-13-2009, 02:48 PM
0949er
0949er's Avatar
are SFC worth it? My local shop was trying to talk me into SFC's as my next MOD. How much do SFC's cost approx? And more importantly, do they get in the way if I never needed to do any maintenance under the car? (replace my catback, replace the tranny, anything under to the car where the SFCs would have to be removed before any work can be done)
0949er is offline
Quick Reply: help my 0 to 60 time
