How to change trans fluid in the tr3650
Old 09-18-2009, 11:14 AM
SpoonyGT
SpoonyGT's Avatar
Default How to change trans fluid in the tr3650
Gonna change my fluid out to the recommended 3.2qts ford recommends and I waas wondering, where is the drain plug on the 3650? Also, can you fill the transmission with fluid from the top? I mean, take off the shifter and pour the fluid in the top like in the car? Thanks for the help and yes I did a search but came back with fuzzy instructions.
SpoonyGT is offline
Old 09-18-2009, 11:19 AM
Sxynerd
Sxynerd's Avatar
The plug is on the passenger side (middle to rear before the tail shaft) and uses either a 3/8's or 1/2 ratchet head, IDR. Use Mobil1 synthetic fluid. Yum, that stuff works! Yes you can take off the shifter to fill it.
Sxynerd is offline
Old 09-18-2009, 11:28 AM
Brute03
Brute03's Avatar
+1 on pulling the shifter to fill it, waaay easier than using the "fill" hole
Brute03 is offline
Old 09-18-2009, 11:35 AM
SpoonyGT
SpoonyGT's Avatar
Oil has to be a little warm right? Thinking about doing this tonight after work. Got a shifter and its kinda notchy and I believe from what I've been reading the fluid change from 3.8 to 3.2 should fix my 1-2 shift clunk and maybe help my 2-3 shift problem. Thanks for the help on the fluid always good to have real world input!
SpoonyGT is offline
Old 09-18-2009, 05:00 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It's ATF, it flows like water at normal temps...
cliffyk is offline
Old 09-20-2009, 11:21 AM
SpoonyGT
SpoonyGT's Avatar
Well I don't know what fluid was in it before. I went with dex III/merc 3.2qts and it helped out a bit but I still need 2nd and 3rd gear synchros replaced.
SpoonyGT is offline
Old 09-20-2009, 11:45 AM
Sxynerd
Sxynerd's Avatar
WTF?!
Sxynerd is offline
Old 09-20-2009, 08:06 PM
SpoonyGT
SpoonyGT's Avatar
My synchros have been toast a while. I'm waiting to have the money to rebuild the tranny.
SpoonyGT is offline
mtgldr
02-03-2024 09:00 PM
Daddys Girls GTs
09-14-2015 08:46 PM
97SN95GT
09-13-2015 09:45 PM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
Quick Reply: How to change trans fluid in the tr3650
