I need help!
Hey all. Just manned up turned my 96 V6 into a V8. The engine, both LH and RH wiring harnesses, the transmission, the instrument guage bezel, fuel lines, axle, master cylinder and hydro boost lines, CCRM, Computer, all engine accesories came out of a 97 donor car from MPS.
Here is my problem: My starter won't turn over when energized. This is what I've done so far:I have tried applying 12 volts to the single pin connector off the distribution box to bypass the start switch. All it did was go click and drained my battery dead. So I figured it may be the starter pulled it and had it checked along with the battery and both were in good shape, in fact the starter was almost like new. After reinstalling I tried it again but with the same results. My fuel pump energizes and I have power to the inside. I have checked the primary fuses at the distribution box and they were ok. It seems like my power is grounding out and not making it to the starter. Any suggestions on which way to turn. I know that I might have a problem from the Auto Theft system that would require flashing the computer to reset it but MPS me assured it should at least turn over. Anyone?? |
have you tried bench testing the starter to make sure its good
Originally Posted by mustangman03
(Post 6507399)
BTW I forgot to mention that its an automatic transmission.
have you tried to turn the engine over by hand to make sure it isn't seized?
Originally Posted by Smokeybear001
(Post 6507710)
A couple of thoghts I've had: Is the CCRM a posible culprit? Another thing I have the whole car up on stands. Could this be why its grounding out? |
Bump - Anyone?
If the ccrm was bad it would still turn over...Mine went out a few weeks ago and my fuel pump would not energize..but car still turned over..
has ur key gotta chip in it?
Originally Posted by fisher2985
(Post 6508806)
I know this starting problem could happen if the transmission were not in gear. But I think the switch would be tied to the gear selector and not the transmission. I could be wrong about that but it seems to make sense. But I haven't done anything to that area through the whole process. I have thru tomorrow to figure this out or I'm turning it over to a local mechanic at MV Performance who does these all the time. I'm sure it's something small and stupid it's just a matter of finding it. |
