neep help asap
Old 09-21-2009, 06:59 PM
Brandon S
Brandon S's Avatar
Default neep help asap
i have a 2004 GT and i was driving home on the highway and went to take the corner and i lost my power steering,and the brakes are weak.What could this be, Im new to the mustang stuff any help you can give me would be appriceated
Brandon S is offline
Old 09-21-2009, 07:38 PM
03BottleFedGT
03BottleFedGT's Avatar
either your hydroboost unit or the power steering pump
03BottleFedGT is offline
Old 09-21-2009, 08:01 PM
Brandon S
Brandon S's Avatar
has anyone on here ever got rid of there power steering?is there any special part to just have manual steering? i figured it would be one of the 2
Old 09-21-2009, 08:12 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
its not cheap
you need these 2 parts
http://www.summitracing.com/parts/FLA-FR1892D/
http://www.latemodelrestoration.com/item/UPR-3008-F-94
99BlackPonyGT is offline
Old 09-21-2009, 08:25 PM
mustangman03
mustangman03's Avatar
Probably your powersteering pump but i would check the fluid in the reservoir and make sure its full.
mustangman03 is offline
Old 09-21-2009, 09:08 PM
Capt Hair
Capt Hair's Avatar
this.
Capt Hair is offline
Old 09-22-2009, 05:23 AM
Brandon S
Brandon S's Avatar
the reservior is full and there is no leaks
Old 09-22-2009, 05:31 AM
Brandon S
Brandon S's Avatar
well im gonna try to figure out the problem today and aslo was wondering if you can get rid of the ac because down here your lucky to drive with the window down
Old 09-22-2009, 06:28 AM
boduke0220
boduke0220's Avatar
belt?
boduke0220 is offline
Old 09-22-2009, 09:27 AM
99BlackPonyGT
http://www.latemodelrestoration.com/item/LRS-19216B
switch that with your compressor...uses stock belt
Quick Reply: neep help asap
