MT broke 2nd gear! Best Option to Fix?
OK first off I have an '03 GT manual trans in my 96 GT. Well, I have no second gear anymore after I missed second and grinded the crap out of it. I assume the syncros are garbage now. Every other gear works.
Is it a T-5 in an '03?
I was told a t56 6 spd from f-body LT1 would bolt up to the t-5 bellhousing. I would assume if this was the case that the driveshaft would have to be modified.
Should I just fix what I got?
Thanks guys for your help!
the t-56 transmission was in 03-04 cobras. so an lt1 t-56 with a cobra bellhousing and driveshaft/crossmember modifications and it should work. the tail shaft on the transmission may need to be changed out as well but im not sure
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
