trick flow heads..stock cams?
Old 09-27-2009, 05:58 PM
grogan
grogan's Avatar
Default trick flow heads..stock cams?
whats your input on this? i would upgrade the cams but im running a stock bottem end and i want a .550 lift cam which wont work with unnotched pistons.
would you wait or buy them and install the stock cams back in them?
grogan is offline
Old 09-27-2009, 07:03 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
DO NOT buy TF heads and keep stock cams in them. If you buy the TF heads you need to get CMS Stage 4 cams.
WannaBeGearHead is offline
Old 09-27-2009, 07:26 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
this
or buy the heads and just wait until you can afford to do the rest....you can have the pistons cut
99BlackPonyGT is offline
Old 09-27-2009, 07:34 PM
0949er
0949er's Avatar
I read on another forum that some guy bought Trick flow heads and had the stage 2 comp cams XE 270s in them. runs fine from the video i watched. just my .02
0949er is offline
Old 09-27-2009, 07:36 PM
0949er
0949er's Avatar
http://www.youtube.com/watch?v=HEtuPEmxmJQ
0949er is offline
Old 09-27-2009, 08:46 PM
97dustang
97dustang's Avatar
i heard that the trick flow heads were designed to work with the stock cams
97dustang is offline
Old 09-27-2009, 08:48 PM
lizzyfan
Underboss
lizzyfan's Avatar
You can get away with aftermarket cams and stock heads, but stock cams with aftermarket/ported heads is loose/loose situation
lizzyfan is offline
Old 09-27-2009, 08:58 PM
dimebag
dimebag's Avatar
Doable, yes... Worth it? Not really
dimebag is offline
Old 09-27-2009, 09:42 PM
ddmsgtr1
ddmsgtr1's Avatar
You may be able to use the stock cams, but you're really not getting your money's worth of out of the heads, you really need to upgrade. And you don't NEED a set of CMS stage 4's, especially since you're a blown application and those are NA cams. If you want the best of of those heads, get a custom grind for your setup.
ddmsgtr1 is offline
Old 09-28-2009, 07:56 AM
nickmckinney
nickmckinney's Avatar
I learned on the dyno that cams over 225 or so of intake duration just lose midrange with the TFS heads and the stock plastic intake without making anymore top end HP. Be real careful how you cam the motor with these heads.
nickmckinney is offline
Quick Reply: trick flow heads..stock cams?
