Passing emissions with Long tubes and no cats???
Is it possible for my 99 Gt to pass emissions with no cats and full length headers? If so how do you do it? I really don't want to spend a ton of money on a catted mid pipe. Thanks for the help.
You will need MIL eliminators and I would take a stock cat, cut it in half, then stick those on your o/r pipe in case they do a visual inspection. If they do a sniff test, you are screwed either way. But if they just do a OBDII scan, you should be fine with the elims.
MD is a bitch on emissions, i'm curious to see if LTs will pass in MD with a catted Mid-pipe.
if you have a reg mid-pipe just throw in a catted one, if you have your stock one its not that hard, i'm sure you can find a friend with one you can borrow.
I am so glad I don't have to worry about vehicle inspections or emissions testing. I have never had a car inspected or had emissions testing done since I have been in the military. No matter where I get stationed at, I just keep registering my cars back home in ohio. I just send in the paperwork or renew online. I do feel sorry for you guys who have to go through it. Especially the ones with O/R pipes.
my part of md doesn't sniff test anything with an OBD-II system in it. just turns the car on and plugs it in. but my car's exhaust reaks, which may be enough to make them look underneath the car. i'm hoping that if they do, the FLSFC block their view. if not, i'll me making a mid-pipe with 2 weld in cats to pass emissions, then just remove it.
we have one right here in westminster, at the westminster airport. that's the one i normally go to, but the last time i went, my car was bone stock. now i have longtubes and an O/R H with my rear O2's turned off in the tune. as far as my OBD-II system is concerned, my exhaust is running fine.
This is true for me as well.
