mgw shifter install
Old 09-29-2009, 09:29 PM
snareman
snareman's Avatar
Default mgw shifter install
I have never installed a shifter before. this is in a 99 cobra. anyone that has done this install please run it thru me step by step. I know it will come with directions but this will help to.everything from removing plastic panel in tray to setting shift stops. I have gasket bob gaskets. do I use those or silicone, or both>do I use locktite on the screws.I have been quoted 150 bucks for install and I am like wtf????? cant be that friggin hard.
snareman is offline
Old 09-29-2009, 09:49 PM
Eduardo
Eduardo's Avatar
wow $150, no dude do it yourself. i did mine about a year ago and did my friends about 2 months ago.
remove shifter boot
remove rubber insulation(4 bolts)
remove the stock shifter bolts(4 bolts)
remove stock shifter
remove plastic pivot ball on the shifter(underneath) and install it on MGW shifter
clean the contact area and use the silicone that MGW supplied you
install shifter and repeat steps backwards
might be a good time to change out your tranny fluid if you haven't already. you're going to love this shifter, so much better than the stock pos
heres a write up with lots of pics
http://www.svtperformance.com/forums...t45-trans.html
Eduardo is offline
Old 09-29-2009, 10:10 PM
Mustang3GT07
Mustang3GT07's Avatar
It's not that hard bro lol. I installed one on my 04 cobra. Just take your time, double check you work, and read the directions.
Where at in IL are you?
Mustang3GT07 is offline
Old 09-30-2009, 03:31 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
With Cobra Bob's gasket you do not need to use any sealant, nor should you...
cliffyk is offline
Old 09-30-2009, 08:08 AM
CaptianMorgan65
CaptianMorgan65's Avatar
also, use locktight when setting your shift stops.
CaptianMorgan65 is offline
Old 09-30-2009, 08:11 AM
Hollister Hoodlum
Hollister Hoodlum's Avatar
wow, 150 bucks for like an hour and a half job tops lol.
It's really simple the directions they give you are very detailed.
I installed my friends on his 99 gt... best shifter available for sure imo.
Hollister Hoodlum is offline
Old 09-30-2009, 08:36 AM
antiv6
antiv6's Avatar
it takes like 30 mins, its super easy. I had to borrow a tool to do it and did the install sitting in a parking lot.
antiv6 is offline
Old 10-17-2009, 01:08 PM
bullitt1861
bullitt1861's Avatar
i have a MGW sts in my 01 bullitt, u really shouldnt have to adjust ur shift stops since the tr3650 trani has internal ones however if u want a much shorter shift you may adjust to do so just make sure all gears fully engage, MGW is by far my favorite shifter, jus dont keep loosening and tightening the swivel bolts or else next thing you know you will power shift and it will sling the entire handle around on you
bullitt1861 is offline
Old 10-17-2009, 02:49 PM
945LSTANG
945LSTANG's Avatar
^^^shrink that sig a bit there buddy.
OP: 150 is ridiculous. theres only four bolts total (not including the handle) in the whole install. they are robbing you blind.
those rates are equivalent to over $200/hr, which is straight BS.
945LSTANG is offline
Old 10-17-2009, 05:51 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The OP has a '96 Cobra, he needs to set the stops with the T-5 tranny.
Something is wrong if you cannot clamp the lever up tightly. I have had the lever off 10-15 times with no issues--it is a very robust clamp.
cliffyk is offline
mtgldr
02-03-2024 09:00 PM
carid
07-08-2016 09:55 AM
robjh22
Suspension
09-08-2015 12:47 PM
vintageaion
09-08-2015 10:45 AM
Webster454
09-07-2015 04:59 AM
Quick Reply: mgw shifter install
