Last edit by: IB Advertising
Browse all: Brake Guides
- Ford Mustang Gt 1996 to 2004: Brakes Diagnostics Guide
Guide to diagnose trouble and recommended solutions
Rear caliper piston problem
So I am doing my brakes (rear rotors and new pads on all corners). My question is: my passengers rear caliper piston isn't going in. The front pistons are the kind you just push back in with a C-clamp but the rear, I found out, is the twist and push type. Well I pushed the caliper in as far as it would go before realizing it was twist kind and I was pushing it in. So I tried to twist it in the rest of the way but no luck. Then I figured I would twist it back out and then back in but I couldn't even get the piston to start moving back in. Why is that? Did I ruin the piston? Or am I just not doing something right? I tried to push the piston is just to get it started then I would twist it the rest of the way but still no luck. I need your help so I don't have to buy new calipers. Thanks guys!
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
inyadreems
08-21-2015 09:10 AM
