Questions about a Mark VIII Engine swap.
Lets start by saying that I did search, but I couldn't find any solid answers. I was acting an *** and popped a head gasket on my car. Long story, but I am not changing the HG since I have had nothing but trouble with this particular motor in this car. Even after a rebuild (Knocking, coolant loss, etc) I would go with a PI motor, but I am taking it from a Pick U pull and Mustangs and PI's are damn near impossible to find. Mark VIII's aren't however, so I am thinking about putting it in my mustang.
I will be getting the long block for $119 so it's cheap enough.
What exactly is required for this swap and I mean REQUIRED, not "Get the 99 cobra heads cause they make more power". 280HP from the Mark VIII is plenty enough for me. So my checklist:
1. Will the stock Mustang wiring harness work?
2. Will the stock computer work?
3. Will the 2v accessories work? (A/C, Power Steering, etc)
4. Will the 2v clutch work?
5. Will the Mark VIII intake work, or will I need the Cobra Intake?
6. Will the 2V headers work on the 4V heads?
Thanks in advance.
Thanks in advance.
Yes
Yes
Yes
Depends on your year and bolt pattern
Get the Cobra
Thanks in advance.
Yes
Yes
Yes
Get the Cobra
Thanks in advance.
Yes
Yes
Yes
Get the Cobra
I'm doing the same swap, motor is completely modular to my cobra, i belive its the cams/intake are the only difference. intake yes, and either entire heads, or just the cams inside. other than that, you have a cobra motor with a teksid block and forged crank
Ok, what about the headers? I think that they will work because the passenger side one has the same part number as the GT, but the driver doesn't. I know that the Mark VIII on the drivers side has the catalytic converter attached to the header, so that may be it.
Doesn't the computer need to be flashed to a cobra since I have a GT, or does it work out of the box. Oh and I think I have the 6 bolt fly wheel.
everything works together except the exhaust manifold, 2v and 4v have different ports... the wiring of the GT will need to be extended though... the only difference is intake manifold and camshafts. I am doing this swap to my GT and that is as far as I know.. it is almost a bolt on..
