NItrous Tune
RE: NItrous Tune
You will need a different tune. Usually the Diablo pulls fuel out for you because the factory tune is pig rich. With nitrous you want to add fuel and retard the timing 1.5 degrees for every 50 shot. I wouldnt recommend you run it on the Diabo tune.
RE: NItrous Tune
What kind of shot are you putting on it? Its proven that yo can run a 100-125 shot with the stock tune as long as you bump timing. Just be careful and make sure you have ALL the safety devices it takes to run it properly.
RE: NItrous Tune
its a 100 wet shot. the only thing i dont have is a window switch but i up'd my rev limiter to 6500 and i always punch it above 2500. So i can run the factory tune as long as i retard the timing which ive done already (2 degrees).
