Vibration in Brakes, Steering
The car is a 2000 GT 5-speed.
I started out noticing a low whirring noise that corresponded with the RPMs. I could feel a slight vibration in the clutch. The car didn't have to be in gear, though it was more noticeable when the car was engine braking. Originally, I believed the problem could have been either a bad release bearing or something worse in the transmission. However, the issue has spread, and now whenever I turn the wheel at all or depress the brake pedal, there is a loud vibration. This to me seems to eliminate a transmission problem, but I can't think of what else it could be.
I had both the serpentine belt and the pulley replaced in August. I had a really bad battery in the car and I thought that might be causing some of the problem, but I replaced it this weekend and it did nothing.
Also, not sure if this is related yet or not, but the windshield wipers will not turn on. I had this checked out and was told they were receiving power but not a signal. The multi-function control switch was replaced to no avail, so I'm not so sure what's causing this as well.
Has anyone else had this problem? Any help would be greatly appreciated.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
