Using 5-30 as for the oil press guage it drops to none at idle
this is my origianal problem why I had to rebuild I had lost all oil press now it's doing it again don't know if it could be the oil cooler
When you rebuilt the engine did you reuse the block? You could have an oil passage blocked. I'd still try putting a mechanical guage on and watch what happens.
i did reuse the block but if it was in the block it would have started right away this started after driving it with no problem for 100 miles after that it started acting up
