trick flow stage 1 cams - MustangForums.com
Old 10-20-2009, 11:02 PM
jrf
jrf's Avatar
Default trick flow stage 1 cams
this is for my brothers 03 gt he is wondering if u can use the trick flow stage 1 cams with stock valve springs nd with have valve to piston clearance
jrf is offline
Old 10-20-2009, 11:12 PM
mrtstang
mrtstang's Avatar
I recently talked to Trickflow about this cam, and they said not to run the stock springs with it. They are selling the cams and springs for $600 btw.
As far as ptv clearence with the stock pistons, it will be very close if they're installed at the advertised specs.
mrtstang is offline
Old 10-20-2009, 11:26 PM
jrf
jrf's Avatar
so now way at all cause i dont feel like changing out the springs
jrf is offline
Old 10-21-2009, 07:54 AM
mrtstang
mrtstang's Avatar
If you absolutely do not want to change springs, then you might want to check out Bullet Racing Cams. Modular Head Shop sells them, and has Bullet grind them to their specs. They have very specific grinds that don't need a spring change. These are the ones i'll be going with, because i don't want to change springs either.
mrtstang is offline
Old 10-21-2009, 11:10 AM
jrf
jrf's Avatar
so what there saying i can use the 4.6 pi stage 2 cams from there without new springs nd the valve to piston clearence will be fine
jrf is offline
Old 10-21-2009, 11:19 AM
mrtstang
mrtstang's Avatar
That's correct.
mrtstang is offline
Old 10-21-2009, 11:26 AM
jrf
jrf's Avatar
Now is there pi stage 2 heads good to get or no
jrf is offline
Old 10-21-2009, 11:32 AM
mrtstang
mrtstang's Avatar
From what i hear, they're pretty good. Eveyone i've talked to, that has bought them, have been very happy. From what i can tell their prices are great too.
mrtstang is offline
Old 10-21-2009, 02:35 PM
stangalator
stangalator's Avatar
hitech stage 2 cam doesn't require a spring change either, you should look into them. A lot of people on here like CMS stage 2 cams but that requires a spring change. I would change the springs anyways because you will put all that money into your car and it would suck to have a weak spring break....
stangalator is offline
Old 10-21-2009, 06:51 PM
NinjaMonky
jrf if your looking for some ported heads, I have some, with comp springs and steel retainers lmk if your interested.
NinjaMonky is offline
jwog666
01-07-2018 07:16 AM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
Featured Sponsors
