What do you GT owners redline at in 4th?
RE: What do you GT owners redline at in 4th?
5th will actually pull like a non-overdrive gear with 4.10's...well at least more than it would with a lesser rear end gear. I bet you can get your car to top out at the same spped as someone with stock rearend gears, you will just spend more time in 5th than they do.
ORIGINAL: guarnibl
probably like 14.8 with a decent driver.
Any decent driver should be able to break 14.5's stock. I've witnessed a friend take his bone stock 04 GT to 13.8's, but don't count on duplicating that yourself, takes one hell of a driver and a lot of runs.
ORIGINAL: Dan02GT
With a horrible driver.
ORIGINAL: guarnibl
It also come down to were you are located. A sea level run nets a 99-04 GT with a decent driver a 14.1. I ran my fastest of 14.0 on a very warm night with just a catback and catted mid pipe.
4.10s with a the 3650 used in a GT will run out of gear at 170ish. A full bolt on GT won't run over 160. The aerodynamics of 99-04 stang hurts performance.
If you are looking for more top end in 4th switch down to 3.73s (why you need more I don't know). But you are sacrificng accleration for top speed in a gear by going down.
ORIGINAL: 02StanGT
What does how much horsepower have to do with how fast you can go. For example lets say with 3.27s I could run my car up to 6050 rpms in 4th gear I would be doing bout 140 mph, a car with 900 hp will do the same speed in the same gear at the same rpms. If you were to change the gears or tires it would be a different story.
ORIGINAL: Dan02GT
ORIGINAL: guarnibl
JT
95 Eagle Talon TSi AWD - 12.7 @ 103mph (R.I.P.)
00 Mustang GT - Back in Action, still too slow.....
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
