stock block capability
What is the max hp/trq that a stock block can handle, if u used all forged... when will the block itself become your limiting factor
I believe i read somewhere around 600hp on a standard bore
K
K
RE: stock block capability
well, about 450 rwhp is the most you could expect the stock engine (stock block, stock internals) to take. 450 rwhp translates to ~530 crank hp, so 500 crank hp is certainly realistic.
the block will be fine, its the connecting rods followed by the pistons that can't take the abuse above those levels.
swap in some better stuff and i think you could get to 1000hp. at which point the whole thing is pretty much a time bomb, but that's normal for supreme power levels.
I would hazard a guess and say that the stock block can make about 550 RWHP before you need to start thinking about a aftermarket one. I think you could get a bit more out of her, but this is safely of course.
09-08-2015 05:21 PM
09-08-2015 11:50 AM
