Just got my car dynoed
I need a base line run before i get my s/c on. not too bad of numbers thoue
] dyno run
nembers were 247.8 rwhp and 290.3 rwtq
] dyno run
RE: Just got my car dynoed
I thought the numbers were really good considering that there are people who have full exhaust only making 250- 260 to the wheels. all my mods togther cost about $700 as for with the s/c I plan on making around high 300 maybe 400 rwhp. i'll be running 10 or 13 pounds of boost with and aftercooler. on vortech thay say that 8psi + aftercooler is around 402 hp ( crank probly) so i think with 10 or 13 i'll be right at 400 wrhp.
ORIGINAL: yellow02gt
i think you'll need a mid pipe and a good tune. most guys with stock or close to stock exhaust make high 380's on 10 psi intercooled. the mid pipe will get you 400. honestly, don't go over 10 lbs on the stock motor. 400 is about as much as you can safely make. more than that, and you're pushing it.
but with a good tune and proper driving, you should be fine.
ya i'v asked alot of question regarding the s/c. everyone tell me not to make over 400 rwhp. I'll try to keep it around there. i want to use a power pipe but with the 10psi pully and pipe it will be at 12. do you think that it might be ok?
