Changing Differential Gears - Need No B.S. Answer
Seriously though, a noted scientist at a major university just completed a study proving that Co2 gases contribute little, if anything, to, "global warming". The fear mongering from the left is really repulsive.
Money IS a concern. That's why I'm thinking about doing it now. Based on the stuff I've read, it seems that the labor cost is higher than the parts cost. IF the repair requires taking the differential apart anyway, this would be the most economical time to change the gears.
I'm getting a LOT of really good advice. Thanks to everyone.
Ill say DEPENDS.
If you have an auto tranny, I would say don't even worry about it.
However, if you own a 5 speed, throw a set of 4.10s in there and just simply have a shop "93 tune" your car (hp increase will be minimal and since they will have to re-tune the car anyways for the new gears, it would be done side by side just like what your doing now)
BUT, that is only if you have a few extra dollars to spend, and if not, don't worry about it. It wont be "that" big of a deal to somebody who really doesn't care either way.
Can you tell me more or point me to a reference for this "93 tune"? Will the mechanic know what I'm talking about?
Thanks for your reply.
Gas is heading over $3 per gallon and may very well be on its way to $4 per gallon +, especially if our current administration in Washington gets their way. Calculate your approximate gas cost for a year and then recalculate that at a 2-3 mpg decrease. The numbers can really add up. Think long term. Be cautious. As you said, you already have a motorcycle for adrenalin rushes, so balance everything before making a decision.
I forgot to mention that increasing the gear ratio will also increase the rate of wear on the cars engine, as the engine will be spinning at higher RPM's. More RPM's per minute = faster wear.
Again, many things to consider and what's important to you, or not.
Overall adding new gears isn't going to affect your MPG that much (maybe 1-3mpg) and isn't going to cause a noticable amount of wear and tear, if really any.
And if money is a concern, I would just pass on the gears for now. It will probably cost you an additional $500 for gear install.
WannaBeGearHead;6621602]His gas mileage will not "take a big nose dive." He will probably lose 1-3mpg.
That is not entirely true. The gears will allow the engine to rev faster but just because he adds a steeper gear doesn't mean he will be spinning at higher rpms. He would be at higher rpms if he is driving on the highway but in town he could control his rpms.
you can use a handheld tuner (or a chip burned from a tuner im guessing) to change your speedo
I really appreciate all the good advice.
Thanks, everyone.
I say get a set of 3.73s, most people on here will say 4.10s or GTFO but i think the 3.73s would be perfect for your needs and lifestyle. And realistically like you said your driving 3 miles both ways so yea, fuel economy isn't too big of a deal. When I had 3.73s in my GT I only loss 1mpg thats it. And if you don't kill it or slam on the gas, your not going to notice a huge difference in mileage. Just drive normally and you don't have to worry about it.
