Basic Mods for your 96-04 GT/Mach 1
#101
RE: Basic Mods for your 96-04 GT/Mach 1
I recently purchased a 2001 gt and I wanted to modify the engine a bit...I have a k&n, longtubes, xpipe, and magnaflow exhaust. What should be my next mods?
#102
RE: TECH: Basic Mods for your 96-04 GT
ORIGINAL: buster
the best advice that I can give u is to make sure its made of plastic.......metal kind of hold heat right? Kind of defeats the purpose of a COLD air intake right?
#103
ORIGINAL: bigedog8
no the purpose is it draws air through the fender well so it intakes cold air. how long is that air in the tube rushing into the engine not enough to matter. plus the metal intakes look way better than some plastic piles. besides like stated below if ur that conserned about losing .0000007 hp to the wheels because of the heat u can wrap it to insulate it so it doesnt heat up as much.
ORIGINAL: buster
#104
my mods in the order I did them /// then the order that I would have done them
Steeda underdrive pullies
MAC cold air intake
3.73's
70 mm t-body
flowmaster 2 chamber Loud until the basani x pipes (rember to drill a small hole on the low side of the muffler for a h2o drain they rust)
bassani x pipes
trick flow upper plenum
copper plugs
timming adjuster
how i should have done it.
copper plugs
Cold air NOT MAC
t-body and upper plenum
underdrive pullies ( good one's!)
bassani and flowmasters at the same time
timing adjuster
( this will max your MPG )
now you will be spinning your wheels all over so here is the best money you can spend and most neglected
lower control arms (I like Steeda)
Gtrack stage 1
bumpsteer kit
3.73 or 4.10's, I perfer 3.73 becaues of alot of freeway driving
(This will help in planting the rear end and make the car handle better)
These are very easy to do and not too much $$
Next are the $$$ and hard things. but that all depends on what you have planed for the car.
happy day's
MAC cold air intake
3.73's
70 mm t-body
bassani x pipes
copper plugs
timming adjuster
copper plugs
Cold air NOT MAC
timing adjuster
Gtrack stage 1
bumpsteer kit
happy day's
#105
Oh 1 more thing
on a private test on the upper plenem (dam I can't spell today) the accufab was the best 11hp gain on car with only cat back and pullies then the dragon something ealse and the one I wasted my money on Trick flow @ 8hp.
Get the accufab and TB 75mm. This will max your stock intake on the 2v for N/A cars.
#106
New COP's are now avalable for the 2v and the 3v, 4v are comming soon. These are a great mod on blower cars. Here is the link.
http://forums.modulardepot.com/showt...ight=group+buy
#107
well my friend I live in Canada and have never raced below 50 degrees. There is alot of heat under the hood of a car after its been down the 1/4 mile. You make up your own mind. I don't even ice my intake elbow and dial my car at 14.30 and win most of the time. (Of course I dump the last 50 yards or so)
#109
I have an 02 GT auto. Do you use a shift kit on this tranny or do you adjust the shift points via a programer?
Car is stock as a rock now but on the coming soon list:
K&N intake
Flowmaster exhaust
Some kinda tranny upgrade (shift kit or programer which ever one works with our cars)
70MM T body and plenum
After that I like to think I will be able to leave her alone for a while, but I am sure I will be making plans for a SC not too long after that.
K&N intake
Flowmaster exhaust
#110
For the auto tranny, get the SCT or diablo tuner and adjust your shifts with that.
Don't get the 70mm tb unless you're getting a mid pipe with the flowmasters. I recommend a catted pipe, as flowmasters and o/r pipes are raspy. Now, if you like that, then that's cool. And don't just weld in mufflers; buy a cat back.
If you can afford it, get headers, too. Even shorties are better than stock. I've heard LTs can be a pain for autos.
If you still have money burning a hole in your pocket, buy gears. 4.10s I would think, but no less than 3.73s.
Once you do all that, you can get the tb and plenum.
