speedo correction
speedo correction
So after doing gears and changing tires, my speedo is of by more then i want. Seeing that i have a 96 a tuner can't correct this problem. I know that i have to change the drive gear in the dial, but i haven't been able to find info on how to. Is i just becuase it is just that simple or what? Also, how many drive gear teeth are there. I'd like to only have to pull this apart once. thanks
This should be a speedo gear in the transmission and easily replaced. Just pull the cable where it connects to the transmission and swap it out.
Find out how much you are out of calibration and head over to Ford. I am not sure how much correction you can get, but I had no issue getting one to correct my 5 MPH differential when I replaced my tires/wheels many a year ago.
Jazzer
Jazzer
