doing EGR delete... do i have to turn it off on the computer?
i'm doing an EGR delete and i heard that you have to turn it off with your computer is that true? or do i just cap off the intake cap of the manifold and i'm good to go
The EGR system improves fuel economy and power at lighter loads, mid-rpms, and while cruising, and by cooling combustion chamber temps (already burned exhaust gas cannot burn again, this reduces NOx emissions) allows a bit more timing advance under those conditions. At higher loads and low rpms it is disabled and has no negative impact on power.
It one of the emissions related things that actually helps.
