oil gauge - MustangForums.com
oil gauge
Old 11-23-2009, 11:24 AM
hngrant
Default oil gauge
Yesterday when i started up my 2001 GT i noticed the oil pressure gauge read low. I gave it a little gas and it went back up to normal, but at idle it went back to low. I drove it a little ways and it stopped fluctuating completely and read normal once again. Today I started it up again and it is still reading normal. What could have caused it to fluctuate?
hngrant is offline
Old 11-23-2009, 11:40 AM
WannaBeGearHead
Go Texas!!!
Could be your oil pressure sender that is going bad. If that is your problem, they can be bought for ~$9 and is a very easy fix.
WannaBeGearHead is offline
Old 11-23-2009, 12:30 PM
vanquish
+1 my car does the same thing I need to fix that too.
vanquish is offline
Old 11-23-2009, 05:10 PM
Z28KLR
Z28KLR's Avatar
I honestly wonder about the accuracy/sensitivity of the oil pressure gauges in our cars. I'm almost convinced that it's a glorified "idiot light". Hopefully I never find out the hard way, but if my car were 2qt. low would the gauge reading actually reflect that? Mine always sits dead center of "Normal", whether at idle or at wot. I've been in cars by other makes where the oil pressure gauge actually fluctuates depending on throttle.
Z28KLR is offline
Old 11-23-2009, 05:45 PM
Tim99GT
Tim99GT's Avatar
^^ its just a idiot gauge... Doesnt really do much of anything..
Tim99GT is offline
Old 11-23-2009, 10:58 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It is an idiot "gauge", the "sensor" is a pressure switch set at 6 psi-- anything more than 6 psi will display as normal (mid range or so), less than 6 psi is no pressure...
cliffyk is offline
Old 11-24-2009, 02:28 PM
Ogre
Ogre's Avatar
Unhappy oil pump/sending unit issues
Since I got back from Afghanistan, I had a similar problem with my '00 GT. Started out like you. I would start the car in the morning, and the oil pressure gauge wouldn't move. A simple blip of the throttle and the gauge would jump up to normal. Couple weeks later, the gauge wouldn't come up although engine seemed to run and sound fine. I would start driving, and the oil pressure would come up a few blocks from my house. I suspected the common oil pressure sending unit issue, so continued driving the car.
Couple weeks later, while coming back home from work, the engine started ticking pretty bad a few blocks from my house and would not stop. Opened the oil cap and there was no oil getting to the cam/lifters/top of cyl head. Oil level was full. Figured the oil pump finally went south.
Ordered new high volume oil pump and proceeded to change it out. When I removed my oil pickup tube from the oil pan, you would not believe all the crap stuck in the pickup screen. Now, I am not sure if the oil pump was bad, but I changed it anyway cause I was there and is a little insurance.
The car has 135K miles and I haven't had it that long. There were little pieces of the timing chain guides in the oil pickup where it had obviously broke before, plus little shavings of something that I am assuming to be fine shavings from the guides or tensioner arms. There was so much stuff jammed in there, I had to use a dental tool to get it all out. I am sure that it was restricting the oil flow!
Anyway, almost back together. I plan on finishing it tonight. Ever wonder why so many stangs have ticking sounds? This might be the answer why.
Ogre is offline
Old 11-25-2009, 11:41 AM
hngrant
hmmm sounds exactly like what happened to me. im going to take a look at that
hngrant is offline
jwog666
01-07-2018 08:16 AM
andrew1969
16
01-08-2016 03:48 PM
wraith777
09-28-2015 11:49 AM
MusicCity615
09-12-2015 08:05 AM
Pyrate Dave
09-10-2015 08:30 PM
Quick Reply: oil gauge
Featured Sponsors
