39k mile service.
Just had a few simples questions about what i should do as far as maintanence for my 02 GT
1. oil change, Mobil 1 and Mobil 1 filter *****how often do you Mobil 1 guys change fluid 2. change differential fluid *****what fluid and additives do you all recommend. and how much do I need? 3. Change Fuel Filter ****Is there other alternatives to the OEM unit or should I look aftermarket? 4. Clean Air Filter (k&n) thanks for all the help guys. I just want to know how best to take care of the stang, pleaser add any additional items I should do thanks, Jose |
RE: 39k mile service.
I would change Mobile 1 every three thousand miles.
Differential fluid you need to use 75 weight and a friction modifier. OEM fuel filter is good. Thats all I used and I had it changed every six thousand miles. K&N is a good filter. Look into the Green filters. They are suppose to outflow K&N by a pretty good bit. Also... I would look into a direct fuel injector flush, and a good radiator flush. Just a couple things to think about. |
