Stupid question? PVC valve....Help!!
Old 11-25-2009, 01:29 AM
02mgstang
02mgstang's Avatar
Default Stupid question? PVC valve....Help!!
OK..How in GOD"S name do i get the PVC valve off the valve cover of my 02 mustang gt? The hose running from it to the top of the intake is sucked together when car is running. This can't be normal..CAn it cause idle problems?
02mgstang is offline
Old 11-25-2009, 01:36 AM
teej281
4.6L Section Moderator
teej281's Avatar
I dont think that it would. But why would you have to pull the valve off the valve cover??? Just pull the hose off and replace the hose.
teej281 is offline
Old 11-25-2009, 03:11 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
The PCV* (Positive Crankcase Ventilation) valve has a 1/4 turn camlock thread--you need to turn it 1/4 turn anti-clockwise to remove it...
* - not PVC (PolyVinylChloride)
cliffyk is offline
Old 11-25-2009, 05:25 AM
StriderTacticaL
StriderTacticaL's Avatar
Speaking of PCV valves and not to Hijack the thread but...
I've been looking ALL over for a replacement PCV valve for my car and checked different Ford dealerships locally.
Basically long story short, no one at Ford around here knows what they are talking about. Some have kept ordering me the wrong PCV valve, some have told me the one in my car now is definitely not a factory PCV valve (but it is) and some just have no idea
Anyone know where I can just buy one online???
Thanks,
Brandon
StriderTacticaL is offline
Old 11-25-2009, 05:51 AM
7 UP Mustang
7 UP Mustang's Avatar
Pull it off and clean it with some cleaner. If it rattles when you shake it back and forth, it should be good. Sounds like it is stuck in the closed position hence the hose is collapsing. The hose may be bad from old age too. If you can blow thru it one way it is likely good. The other way most of the air flow will be blocked. Good Luck!
LARRY
7 UP Mustang is offline
Old 11-25-2009, 06:46 AM
cwf340
cwf340's Avatar
The PCV isnt the cause, the hose is just old and collapsed. soon the vacuum will suck a hole in it. then you will have a vacuum leak and the CEL will come on. Go to a dealer and buy a PCV hose, it should only cost around $20. The valve should be ok. Strider, try rockauto.com they may have the correct valve for you.
cwf340 is offline
Old 11-25-2009, 07:00 AM
03BottleFedGT
03BottleFedGT's Avatar
when you go to a ford dealer to order you pcv tell them you need the heated pcv valve then you will get the right one
03BottleFedGT is offline
Old 11-25-2009, 09:41 AM
02mgstang
02mgstang's Avatar
Thanks guys for all the input...I didn't want to break anything trying to get the pcv valve off. This site is so handy...I guess a stupid question is a question not asked or when you ask it wrong (PVC)...But you guys knew what i meant anyway....Thanks again....BTW..Nothing wrong with PCV..It was the hose....
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Stupid question? PVC valve....Help!!
